Exhaust Manifold Sealer?
Sam S.
03-16-2007 04:59:15
The outer edges of my exhaust manifold area of the head have rusted and deteriorated over the years on my 48-A. The intake portion looks like new, but the exhaust has narrowed to about 1/4" in some areas. Surfaces still look fairly flat though.
Is there a sealer/compound that anyone has used to help assure a good seal longer, with a standard gasket? Thought of #3 Aviation but don't think it will hold up to the exhaust temp.
Thanks,
Sam
Thanks,
Sam
Paul from MI
03-16-2007 05:18:44
 Re: Exhaust Manifold Sealer? in reply to Sam S., 03-16-2007 04:59:15
I assume you already have the head off and the manifold removed to check the gasket surfaces. If you have gone that far, why not have a machine shop re-surface them both. Cost isn't that much and you'll get a better job in the end. Also, I use stainless steel nuts when you reinstall-saves trouble later. Good luck,
Paul
MyrlfromPA
03-16-2007 05:13:43
Victor has an exhaust sealant in a tube that is about like furnace cement. Works real well. Also rutland furnace repair works good too.Autozone Advanced auto or napa should have the victor and most any hardware has the rutland.
