Any propane experts??
moline
03-15-2007 19:24:22
I have a 60 propane.It runs like a top and used to start good.Now it will pop and die when I try to start it.I have to keep pressing the primer button to get it to pick up speed and run.When it catchs and runs it runs fine,no loss of power or missing.The air filter is full of the proper weight of oil and it has new points and plugs and cap and rotor(set to propane specs).The timing is right on spec.The primer will gurgle in the air cleaner if held down.It seems to be getting plenty of fuel.When it gets warm it will run on liquid and the throttle response is quick and responsive.It just wont take off and run like it used to.Any ideas? Thanks,Moline
lozol
03-16-2007 18:13:01
 Re: Any propane experts?? in reply to moline, 03-15-2007 19:24:22
I had one LP tractor that i had worn intake valve guides and was low on vacuum and would suck fresh air threw the guides, replace the guides and no more problems. another tractor installed electron ignition, another one would start just fine with the oil bath off, Glenn is right there is on experts
Jim in AK
03-16-2007 01:06:20
Rebuild your Evaporator / converter or have your L.P. dealer rebuild it. That should take care if the problem.
Jim
Glen in TX
03-15-2007 22:41:27
Could be faulty ignition yet with not correct voltage to coil or wrong resistor? Make sure solenoid valve is staying on keeping fuel to carb. Bad wiring to ignition, strainer solenoid or if electric primer? Vent hole plugged on back of converter. Bad low pressure diaphram in converter. Binding metering valve or linkage. Other causes not starting properly on vapor or maybe one valve is bad with excess flow disc sticking at times, primer not working or over priming. Lean mixture caused by leaking gaskets. A no fuel at carburetor test can be done by opening liquid valve and while ignition is on press primer button listening for a hissing sound. If no hiss no fuel flow but sounds like you have fuel flow. LPG systems are covered in JDs SM2015 LPG Equip. service manual and copies available from Ed 812-537-4622 or JD 800-522-7448. Might not hurt to see if something broke or out of wack on valve train too messing up timing? There are no experts on propane. Always have respect for it and when you quit learning or lose respect for it you could become a causalty.
