carb # question
BLinWMi
03-15-2007 19:19:26
looking to the great Green gurus. I went up to the old farm today to get a tracor out of storage. While getting to that I found some pails of parts in the corn crib. One pail had 3 carbs in it. One if them I think is to my AO, but not sure which one, and have no idea about the other 2. There is a TSX 60, I have an LUC and an LI but they both have the carbs on so not sure what this one fits. It has a mud dauber nest in the bore of it so it came from down south somewhere, not a Michigan native. Also found a DLXT 67 and a 71, like I said probably one of these was on my AO but which one. And what does the other one belong on. Next question, found a Wico mag that I have no idea what it could be to. It is gear driven and has the short external jumper wire from some point on the cap to the internal coil. Oh and it has yellow paint on it, not like it was repainted, old yellow paint. I know the L series used the gear driven mag but what else did? I have never taken the mag off my LI but it is possible when I bought it this mag came as a spare, and my sometimers disease doesn't remember it. Appreciate the help
Glen in TX
03-15-2007 22:20:13
 Re: carb # question in reply to BLinWMi, 03-15-2007 19:19:26
The SM2024 carburetor manual shows the TSX-60 to fit LUH engine on a 12A combine also shows fits LA tractor serial # 1000 and up and LU tractor # 1000 and up. I think it probably should have said LU series power units # 1000 and up as that agrees more with the Marvel Schebler catalog. DLTX-67 fits B tractor B201000 and up, all fuel. DLTX-71 gasoline carb fit A # 584000 and up and AR - AO # 272000 and up. The Wico mag if doesn't say XH-909 or C-909 is probably not for a L series JD. It could be a CAT pony engine mag if 2 cylinder gear drive but those usually have a special tag saying Caterpillar on them. Could be several others like Wisconsin, Hercules, Waukesha or others. I dont' remember MM using a gear drive mag. Just put a Wico tag spec number and number of cylinders on here and Duane or I or others can tell you exactly what it fit.
