HELP !!! Please !!
Les Mack
03-15-2007 18:35:39
I have a '41 A and haven't had any luck finding parts or info for the fan to mount on the fan shaft. I have an IT maint book, but it doesn't describe or illustrate the assembly that came off my tractor. Mine looks to be original Deere. It only has what looks like a hard rubber bushing about 3" long that goes in the fan housing and over the fan shaft. All the illustrations show friction disks, springs etc. My tractor does not have a water pump or a pulley on the fan shaft. Really confused guys, HELP.
Les Mack
03-16-2007 20:13:15
 Re: HELP !!! Please !! in reply to Les Mack, 03-15-2007 18:35:39
Thanks Guys! I finally got the sleeve off the splined shaft and cleaned up so it moves freely with the spring pressure. I put a washer between the fan hub and the cone keepers so the fan can't get into the rad. While I was that far into it I reset the govenor timing. Hope to get it finished up and running again tomorrow. Again, thanks a lot!!
Mike M
03-16-2007 06:56:50
It sounds like you have the original rubber hub fan. There are no pieces to these as it's to be all 1 piece. Unless yours is falling apart from old age and the rubber is loose from the hub. Then your giong to have to get a later assy. Otherwise you just slip it on the shaft,compress the bearing and spring inside the fan tube by pressing down on the fan hub and then slip the 2 half moon keepers in.
jc37A
03-16-2007 06:28:41
My old rubber bushed fan worked its way forward off the shaft into the radiator on my '37 model A. I changed to the clutch fan set-up found on later models to keep that from happening again. Hope this helps!
Les Mack
03-16-2007 05:22:17
Thanks for the comeback, Ben. So. Tx. I have taken the fan with the rubber bushing to the dealer and we went through their original JD books and did not find the set up as it is on my tractor. Been hunting for an A service manual that would cover the correct model number without any luck for quite a while.
Ben.So.Tex
03-15-2007 19:14:15
Get a picture/print out from your dealer and that may help. they may have been converted later on I also have a 44 B with the rubber bushing..You may want to check the archive also. GOOD LUCK BEN
