720 D Electric start
Mark 2 in Ohio
03-15-2007 09:31:03
Hi,
I've made a decision to remove my pony and convert to Electric start. I have an original starter bracket, but want a 12 volt starter. I know of starters by themselves that are $500 - kinda pricey. I know of kits with a starter, bracket, other pieces, etc for $900. Which route is best to take? This tractor gets usedfor farm purposes and has a recently overhauled engine, so it starts right up (but with a pull due to broken pony rods)
If I buy just the starter and use my bracket, how hard is hooking up the wires, cables, etc.
Looking for your input and DONT say fix the pony.
Thanks!
kent dakin
03-22-2007 12:14:36
 Re: 720 D Electric start in reply to Mark 2 in Ohio, 03-15-2007 09:31:03
Been looking for a starter for my 720 for almost 6 weeks...they are very hard to find & very expensive....stay with your pony motor...I can't even find anyone that will rebuild my old starter for less than $600.oo...Delco part # is 1113093...good luck...Kent
Greengo
03-20-2007 13:55:32
Thats the best thing you can do is change to electric start--Don't care what anybody says--You will be so happy you will want to start every day just to know that you can!!
MyrlfromPA
03-16-2007 05:40:09
I used a delco 12V starter with a 13 tooth cat bendix ( V8 Cat i think) and made my own bracket for my 70D and changed the oil filler cap to a breather. Cables are made from welding cable and wiring is not hard to change. Mine did not have the starter button as the 720's do but use a ford type seloniod between the factory button and big starter. fuel gauge on mine is factory sender and int truck gauge for 12 neg grd. any other questions just email me and I will do my best to answer. I check about every morning but may be a day or two in getting back to you.
buickanddeere
03-15-2007 18:42:54
The Delco site lists all the hundreds of versions 40MT,41MT & 42MT starters, nose cones and 13 tooth pinion gears. At least carefully clean, package,label and store all the starting engine parts so somebody doesn't forget where they are or throw them out. A converted tractor looses a couple of thousand in value around here. By the time you are in for two HD batteries, a new battery box, fuel gauge, fuel sender, charging system, starter and wiring modes. You will be in over the price of a used running starting engine.
GPULLER
03-15-2007 13:36:21
I converted my 720 over to 12V electric start also. I used the bracket, throttle linkage bracket that is mounted on the governor, intake, water manifolds, crankcase breather from a 730. The original manifolds can be used but the holes for pony motor coolant and exhaust will have to be plugged, also a block off plate will have to be made for the right side of the block. I had a starter that is the same frame size as the 24V 730 starter, had to get a new nose cone and bendix, the diesel ring gear stayed the same. I installed a GM 12V alternator, did not use the original harness. The light switch is still used along with the starter push button. The divider in the pony motor battery box was rusted out, it was removed so two 750cca group 34 batteries could be used. Went to NAPA for custom made battery cables. I works very well, don't miss the pony one bit. Any more questions feel free to drop me a line.
Blksmok
03-15-2007 11:01:58
Mark...I did the reverse of what you're planning. I converted a JD70D from an e/s back to a pony engine. Whoever did the original conversion used a heavy duty JD starter and the ring gear on the flywheel was from a 70 gas.So, you may need to change the ring gear in the process.
Mike M
03-15-2007 10:19:58
Ohio is full of barn banks and I'm pretty sure those JD diesels is why ? LOL
Check around some of the truck parts stores for a starter you should be able to get on for less than $500 I think they are the same frame and you can move the nose piece around to different spots. There are a couple of different tooth count drives , but I don't know which one that takes.
