JD 2640 Lift and remotes are slow
PNM -GA
03-15-2007 09:19:44
Have a JD 2640 that the rear lift and remotes are slow but do work although they get worse the longer the tractor runs. I did have a problem with hyd. filter stopping up, but changed the rear brakes to fix which seems to have worked because the brakes and steering work fine. There was some silver residue in brake housing but not as much as I thought. Seems to me something has stopped up during the brake change since everything was working before. Any suggestions?
Tx Jim
03-15-2007 09:25:38
 Re: JD 2640 Lift and remotes are slow in reply to PNM -GA, 03-15-2007 09:19:44
Have you checked stand-by pressure? It should be 2250 psi. Possibly has an internal high pressure leak,maybe rockshaft or steering valve. When you repaired brakes did you clean sump screen? Tx Jim
PNM GA
03-15-2007 16:59:07
 Re: JD 2640 Lift and remotes are slow in reply to Tx Jim, 03-15-2007 09:25:38
I haven't started checking pressures yet but wanted to know where to start first. I did check the sump screen and it was clean. I still can't figure why it slowed down after I changed the brakes when it was working fine before. Seems like it may be a stuck control or relief valve.
Thanks
Tx Jim
03-16-2007 04:46:24
 Re: JD 2640 Lift and remotes are slow in reply to PNM GA, 03-15-2007 16:59:07
Pull the pressure control valve and see if it's stuck. It's on RH side in front of hyd. filter. Tx Jim
