3020 road speed
JR inTX
03-15-2007 07:01:49
How fast does a 1971 3020 go in 8th gear with a syncro-range? I have one and with the shift lever all the way back and running at 2000 rpms it goes about 12 mph. I drive it to the gas station down the road to my field sometimes and it's about 2 miles. My ops manual says about 17 mph. Is something wrong? It is a diesel also.
DeereManJRC
03-15-2007 09:52:55
 Re: 3020 road speed in reply to JR inTX, 03-15-2007 07:01:49
We have a 3020 powershift that goes a little over 20mph at pto rpm. We have also had a 3010 with syncro range and both tractors had almost identical speeds in 8th gear. That was with 15 5 38 tires as well.
Gerald J.
03-15-2007 09:33:44
Did you have the speed drum set for 7th or 8th gear? At 7th it would show 12 mph for 2000+ RPM.
Gerald J.
JR in TX
03-15-2007 09:52:55
 Re: 3020 road speed in reply to Gerald J., 03-15-2007 09:33:44
No I didn't, does that affect any thing other than tell you how fast you are going?
Gerald J.
03-15-2007 16:32:03
 Re: 3020 road speed in reply to JR in TX, 03-15-2007 09:52:55
It has no effect except on the driver. If its set for 7th gear, you won't see a speed indicated over 12 mph, even though its doing 22.
Gerald J.
JR in TX
03-15-2007 08:17:05
Yeah I tried the overide and the engine was screaming but it did not go much faster. I have 15.5-38 tires and no load.
j cook/iowa
03-15-2007 08:18:14
 Re: 3020 road speed in reply to JR in TX, 03-15-2007 08:17:05
Have you adjusted the clutch?
JR in TX
03-15-2007 08:39:03
 Re: 3020 road speed in reply to j cook/iowa, 03-15-2007 08:18:14
No I have not, is that something you can explain here or is it too complicated?
Gerald J.
03-15-2007 16:38:27
 Re: 3020 road speed in reply to JR in TX, 03-15-2007 08:39:03
With the engine running 1900 rpm there is supposed to be 1 to 1.5" of pedal free play. Its adjusted by tilting out the battery and loosening the big nut on the clutch shaft and the small bolt through the curved slot. You have to take out a cotter key to loosen the big nut.
If there is no free play, the clutch is slipping and its not been improved or had its life lengthened any by that slippage. If the clutch is slipping it will slip worse going up hill or with a load on the hitch behind.
Gerald J.
j cook/iowa
03-15-2007 08:10:29
There is a throttle override which allows you to operate the tractor at 2500rpm. That is where your 17-18mph road speed is!. The "rated" speed of 2000 rpm is the engine spee where your pto is turning at the designed 540 or 1000 rpm. You arn't operating the pto while driving at road speed are you?
Gerald J.
03-15-2007 07:48:27
I get 22 mph on my 4020 at 2500 rpm unless there too big a load behind it. With 30,000 pounds of wagons and corn I could only get 16 mph, but then the engine speed was only 1600. I only did that once and I won't do that again.
The hand throttle should go up to 2250 (have to pull out on the knob) and the foot throttle to 2500.
Gerald J.
dm
03-15-2007 07:44:34
what is your tire size?
Gerald J.
03-15-2007 09:31:48
 Re: 3020 road speed in reply to dm , 03-15-2007 07:44:34
I was running 18.4-34 on my 4020.
Gerald J.
Mike M
03-15-2007 07:22:30
That 17mph figure MAY be at a higher speed than 2000 rpm see what the max. rpm is to be set at for the foot throttle or hand throttle with the knob pulled out and I'm betting it's higher.
