4020 rockshaft / load control update...
Jason Z in MO
03-14-2007 20:45:03
I found a good used rockshaft housing so I moving forward again! Since I have it off I thought I would replace the rockshaft seals. Any good tricks to getting the arms off the tapered splines of the rockshaft?
On the load control stuff... I went to my dealer to order parts etc. I got into a "discussion" with the parts manager who is a friend of mine. I was wanting to go with aftermarket bushings (o-rings), seals, new shaft etc. He talked me into going with John Deere bushings (no o-rings) and JD seals. If I replaced all the parts with JD parts; shaft, seals, bushings, wishbone bushings etc; he would guarantee it for 2 years. Parts and 15 gallons of oil. I'll be putting this back together tomorrow night. Am I doing the right thing?
What has me most worrried is the bushings in the transmission case are not tight anymore. They are a snug fit but I can get them in without a driver. He told me to use loctite bearing retainer.
I did check the front wishbone bushing and pin. A new pin and bushing allows for ~1/4" of front to rear movement. I measured the movement of the wishbone and it's just less then that. So it's staying together.
Thank you all!
Jason
Mike w J
03-15-2007 11:04:20
 Re: 4020 rockshaft / load control update... in reply to Jason Z in MO, 03-14-2007 20:45:03
My seal and bushings came from JD In a sealed JD bag and the bushing had orings in them.
Jason Z in MO
03-15-2007 21:48:20
 Re: 4020 rockshaft / load control update... in reply to Mike w J, 03-15-2007 11:04:20
Do you happen to have the part number yet? They told me JD didn't make the o-ring type and I couldn't find any reference in the online parts catalog. What is the SN of your tractor?
Glen in TX
03-15-2007 10:25:19
Did your parts man know if the oversize OD bushings were still available from JD? They were still in online parts catalog last time I looked but you need to measure with calipers before going that route but those have been a option for a long time unless discontinued. JD seals can work fine too the key thing is to always take up the wear and slop in everthing like all the pins and wishbone slack and replace shaft. Anytime you can just barely see a scratch or feel a line with fingernail the shaft is junk and needs to be replaced.
Jason Z in MO
03-15-2007 12:17:11
 Re: 4020 rockshaft / load control update... in reply to Glen in TX, 03-15-2007 10:25:19
The oversized bushings are available in .003, .006 and .030" but the cutter tool is no where to be found... .003" would be too big without machining, My case isn't that worn.
The last time I did this I didn't replace the shaft or wishbone bushings but I am this time. I really can't see a problem comparing the old wishbone bushings to the new. But I didn't think there was a problem with the shaft either! Based on your comment "barely see a scratch or feel a line with fingernail the shaft is junk..." my old one was trash the first time! I'm sure glad axle shafts are more forgiving!
I'm amazed at how tough those shafts (pins) are. Now I have another punch tool!
Glen in TX
03-15-2007 15:31:58
 Re: 4020 rockshaft / load control update... in reply to Jason Z in MO, 03-15-2007 12:17:11
I wondered after making that comment if you could find the cutter tool. Maybe punching some inside and loctite will work. Yeah those shafts are tough stuff and about you can do is grind on them or cut with abrasive saw. You'll ruin a bandsaw blade trying to cut one. I cut a larger one up from 6030 wire welding on plates for hitch pins once lol. Wasn't a good idea!
Mike M
03-15-2007 07:27:49
Well if everything is new it should hold up and he is going to warranty it ? But I got my aftermarket bushings right from my dealer as they keep them in stock. It should work either way as long as the side play is gone and the wishbone bushings are tight or within spec. if there is a spec. ?
Jason Z in MO
03-15-2007 14:58:23
 Re: 4020 rockshaft / load control update... in reply to Mike M, 03-15-2007 07:27:49
The first time I got the aftermarket bushings from Deere too. Different parts guy that time. This guy says to use all Deere parts and he would warranty. I will shim to remove any side play.
The little caps that are held in place with a single capscrew from the bottom sure don't stay tight. They won't fall out but the tops just flop around. Nothing seems broken. I will look for a way to secure them.
Glen in TX
03-15-2007 15:46:56
 Re: 4020 rockshaft / load control update... in reply to Jason Z in MO, 03-15-2007 14:58:23
Probably need new retainer plates and bolts if they use those instead of snap rings. Seems like once I rotated them a tad drilling new holes for bolts because I was in a hurry and they would have to order plates and put silicone behind them. Seems like I remember it not working well? If plates are worn in tong area fits to shaft replace them.
