Grain Drill identifcation
Oliver1800A
03-14-2007 20:15:45
I have just picked up a 24 hole 7 inch spacing drill. I think it is a B or FB model. It has no tag. It has both fert on back and small seed hoppers on the front. Two cranks for adjust height on the front so no cylinder. Around 17 feet wide. Looks like prior to the 8000 series. Has Van Brunt on the front. Any tricks to ID this rascal so I can get a book for it? Any help appreciated.
Tx Jim
03-15-2007 03:56:56
 Re: Grain Drill identifcation in reply to Oliver1800A, 03-14-2007 20:15:45
JD only built a B drill in plain grain version,no fertilizer! FB model has galvenized box with flat spinners in bottom of fert.box to dispence fert. Shoots for fert. to grain cups were held on with wire holders. Tx Jim
Glen in TX
03-15-2007 10:30:41
 Re: Grain Drill identifcation in reply to Tx Jim, 03-15-2007 03:56:56
That's true but they did make external add on fertilizer boxes and grass seed boxes for most all of them. Maybe not the B ? I have several fertilizer attachment manuals for the drills someplace. The FB series are just all in one box with two lids though.
Glen in TX
03-14-2007 20:28:16
third party image
Above is rear view of a FB. Front view and more pics on implement photos in Galleries section to your left. Enter my handle or John Deere grain drill or your model at implement photos in search box as I've posted some JD drill pics there before and could be others on there too to help you ID it. Search implement alley forum also. Look closely on back side of box and might see where FB was once stenciled on or may not. Those were made way before 8000 series drills as there were Van Brunt B, FB, FB-A, FB-B, S, E, R, then John Deere DR, DR-A, DR-B and several others in hoe drills and variations.
Oliver1800A
03-16-2007 12:22:08
 Re: Grain Drill identifcation in reply to Glen in TX, 03-14-2007 20:28:16
Glen,
I sure do appreciate the help. I have some pictures that I should send to you but I know we are warm on this. I just wanted to order some parts and books for it. I know the boots and drops are the same on most Deere drills. The double disc opener bearings material will help as well. I just not taken one apart yet. I will get a photo to you if that helps. Thanks again,
DAVE
Glen in TX
03-16-2007 17:35:47
 Re: Grain Drill identifcation in reply to Oliver1800A, 03-16-2007 12:22:08
Sure, send JDK or I some pics if you can't put them on here. Another way to do it is post pics here on YT on help identify or implement photo section and let us know or link it from there. Any trouble getting parts local for old JD drills give Burrells a holler in Oklahoma. Burrells can convert or trade openers with you too many times if you want to go from single to double disk or whatever also. All I have parts for now really are some JD LZ hoe drills. Once you get it identified can find manuals many times on ebay or online ads or from JD publications 800-522-7448 or http://techpubs.deere.com
JDK
03-15-2007 13:16:23
I dont mean to hijack this post, but I may have related info for Glen and anyone else.....
I have repair and parts catalogs for old equipment. If anyone is interested in identifying or getting illustrations for something older you can write back.
The catalogs have drills, seeders, sowers, cultivators, planters, disk harrows, endgate seeders, horse-drawn stalk cutters, and other old equipment. Some of the earliest drills go back to 1890 and up to 1942.
Glen in TX
03-15-2007 16:07:42
 Re: Grain Drill identifcation in reply to JDK, 03-15-2007 13:16:23
No problem that's good to know. Sent you a email JDK to talk about what you have. That's what I got by are my collection of old manuals I picked up at dealer auctions. Something others might want to watch for are reprints of the old JD Centennial booklet called "Power Farming with Greater Profit". That booklet shows unstyled letter series tractors, combines, planters, potato equipment, beet equipment, plows, disks, oneways, planters, drills and implements you don't even always find in old pocket ledgers. It shows some older Van Brunt drills: EE, F, SS, LL, ZZ with tall steel wheels and also a OO grass seed drill and H lime distributor. Can't remember where I got the booklet but several of the antique magazines have catalogs of reprints of this type.
