2510 SN?
Deerly Parted
03-14-2007 20:09:38
I found a plate on the engine and on the rear of the tractor. Which one is the tractor SN. I assume the rear but should they match or not? Which numbers are the SN, since there are numbers and letters mixed together?
j cook/iowa
03-15-2007 08:17:18
 Re: 2510 SN? in reply to Deerly Parted, 03-14-2007 20:09:38
Your serial number plate likely reads something like this:
713R012345R
Correct?
Breakdown of the serial number:
7=first digit= 2510 0r 2520
1=second digit= row crop chassis (A 3= high crop)
3=third digit= diesel engine (1=gasoline, 2=lpg)
R= synchro-range tranny. a P = powershift
012345 = SERIAL NUMBER
R= Built in Waterloo Iowa
If the 1st digit had been a 1, you would have a 3020, first digit = 2, and it's a 4020
Glen in TX
03-14-2007 20:34:17
Number on rear tag tells you the year from serial number lists. The engine tag will have a serial number in it also but should tell you in code that it is a tractor engine, diesel or gas, and cubic inch size like 180 for gas or 202 for diesel. You can send send the complete number off tag on rear to Two Cylinder magazine also and they can do a serial number research on it for a fee. Find out when exactly made and where delivered to originally.
