68 JD 350
Paul Jelinek
03-14-2007 19:41:07
Does anyone know if there was a back hoe available for the 1968 JD 350 gas? If there was did it need additional hydraulic power? Are these a capable machine? Any areas of concern?
Thanks
Paul Jelinek
03-15-2007 18:23:52
 Re: 68 JD 350 in reply to Paul Jelinek, 03-14-2007 19:41:07
Thanks Roy, makes sense. I don't suppose the backhoe attachment is quick change?
Roy Suomi
03-15-2007 17:57:53
With a backhoe mounted , the front idlers never see any ground..The sprockets and finals get all the weight...
DLM
03-14-2007 21:31:23
Backhoes were available for the JD 350. I think the 9250 was one of the models the 9250 had open or closed center hyd. for the 350 you need open center. If your 350 has a dozer it proberly has the small pump when you put a hoe on you need the larger pump also a flow devider and a deviter valve the deviter valve has a relief in it for the hoe. there were some more models of hoes but i can't think of them right now there is one that has a hyd. tank built in the frame for more oil and cooling. Don
Paul Jelinek
03-14-2007 21:36:18
 Re: 68 JD 350 in reply to DLM, 03-14-2007 21:31:23
Thanks. Any issues with these machines that you know of?
mark ace
03-15-2007 19:08:41
 Re: 68 JD 350 in reply to Paul Jelinek, 03-14-2007 21:36:18
9300, i have one on my 350 dozer, it works good but the front end is pointed to the sky. i also have a 555 and it works much better on that machine do to it having a loader and weigh more
