3010 load control shaft driver
bluesky
03-14-2007 18:20:22
will leaking seals on load control shaft keep the tractor from moving?
bluesky
03-15-2007 04:16:45
 Re: 3010 load control shaft driver in reply to bluesky, 03-14-2007 18:20:22
ok,thanks. so if bearings aren't gone,adding hydrotran should make it go....
Bob
03-15-2007 08:31:01
 Re: 3010 load control shaft driver in reply to bluesky, 03-15-2007 04:16:45
Since the 3010 was not available in powershift and does NOT have a wet clutch it has NOT failed to move from the oil simply leaking out.
(Unless it has been driven long enough that way to have done serious damage as I said in the other post.)
Was it working when parked and later wouldn't move or is there more to the story as to how it failed?
bluesky
03-15-2007 08:48:53
 Re: 3010 load control shaft driver in reply to Bob, 03-15-2007 08:31:01
Bob, I don't know full story and it appears that seller either isn't giving me full story or doesn't really know what problem is. I have yet to see tractor. probably look at this wknd. My neighbor is former JD mech., so I'm hoping to drag him along.
thanks
Bob
03-15-2007 08:52:17
 Re: 3010 load control shaft driver in reply to bluesky, 03-15-2007 08:48:53
Please post back with what you find!
Bob
03-14-2007 19:56:43
Yes but only after ALL the rear end oil leaks out and the transmission bearings seize from lack of oil!!!
