4010 with coolant in the oil
Dwayne TX
03-14-2007 09:36:43
I went with a neighbor to look at a real clean 4010LP. The guy selling it said a little coolant shows up in the oil when he changes it. Not familiar with the engine - what's the likely source, head gasket or does it have liners with o-rings that could be shot?
61-4010
03-15-2007 05:03:08
 Re: 4010 with coolant in the oil in reply to Dwayne TX, 03-14-2007 09:36:43
Not sure about the LP variety but I bought a 4010D with the same issue....coolant in the oil. I tore the block down and discovered HUGE amounts of pitting in the block where the sleeves are sealed with the o-rings. 2 of the 6 sleeves had holes in them.
Check out the link Link for some photos. Needless to say, I've had to get a new block, total rebuild kit and lots and lots of money.
G/MAN
03-14-2007 16:29:54
Most likely by far is leaking liner o-ring seals. Only broken Deere wet-sleeve block I've ever seen was one that someone used a hammer and punch to drive the liners out on. Even pitted-through liners are relatively rare, even when the cooling system isn't maintained at all. I've drained coolant that would make pond water look good out of Deere engines many times and still hven't seen a pitted-through liner, although I've seen leaking o-rings on a few different occasions. Deere engines are far less prone to cavitation and pin-holed liners than some other brands (most notably red ones). There are weep holes drilled through the block that intersect a small groove between the two-o-rings. The upper o-ring keeps coolant "up", the lower o-ring keeps oil "down". The weep hole is there to allow oil or coolant (99% of the time coolant since there is far more cooling system pressure than crankcase pressure and it's only splash oil at the bottom of the liners) that gets past the o-rings to escape instead of ending up where it doesn't belong. However, the weep holes get tightly plugged with dirt or rust, the leaking coolant can't escape and cooling-system pressure pushes the coolant down past the lower o-ring and into the crankcase. Drain the oil, drop the pan, pressurize the cooling system with a pressure tester setup and start looking for a trickle from inside a liner or around the outside of one.
justfixin
03-14-2007 15:30:38
could be broken block
Mike M
03-14-2007 10:04:57
Those have liners with o-rings. Could be an o-ring or could be a hole right through the sleeve.
