Convert a 4010D to 12 volts or fix the 24 volt sys
Tim in Western
03-14-2007 07:42:54
Anybody ever convert one?
What's involved? New starter & Alternator?
What's the pros and the cons?
I have either a bad selinod or a bad starter now, so I'll have to buy some parts.
thanks!
Randy Varilek
03-19-2007 14:27:59
 Re: Convert a 4010D to 12 volts or fix the 24 volt in reply to Tim in Western PA, 03-14-2007 07:42:54
I have a couple of used 24 volt 4020 starters that came off of a 105 diesel combine(same engine). Can send you one for 50 plus shipping. Both my 4020 and 4620 are factory 12 volt so i have no use for them. Let me know.
Jd 40203020
03-15-2007 09:16:15
I would switch it to 12! A delco alternator will rubn about $40. The Motorola deere sells is a lot more $$ but does the same thing. The starter will be more. If you have a hard starting tractor or its cold where you are you will definately want to go with the Denso starter! Otherwise you can get away with the cheaper delco. Other than taht a couple wiring changes and you are all set.
buickanddeere
03-14-2007 20:29:10
If you convert it to 12V. At least take every 24V peice after cleaning them up. And pack them in a labeled box in a safe place. Tell other family members where the parts are. Someday some crazy restorer may want them.
G/MAN
03-14-2007 16:36:21
If it's the solenoid, you can fix your 24-volt system relatively cheaply. If the starter motor itself has taken the trip, they can get expensive in a hurry. Overall, the 12-volt conversion is a pretty good idea, especially for a working tractor that won't have the "correct police" chasing after it. The 24-volt system was and is fine as long as it's maintained and the electrical system load is equally balanced between the two batteries. The problems start when guys throw on some extra lights, a fender radio and whatever else that are all 12-volt items and only connect to one of the batteries. That battery gets drawn down constantly and consistently and soon you have one good battery and one junk battery. Deere sells a very good kit. Haven't seen any of the other brands, but they're probably all about the same. I'd definitely do some pricing - don't assume Deere will automatically be more expensive, and take a look at the WARRANTY on the components in the kit and factor that into the cost. And it's not just a question of changing the starter and adding an alternator. Been a while since I've done one, but I think there are maybe some relays and such that are installed in order to tie the two halves of the electrical system together.
DSK
03-14-2007 14:29:29
Converted my 66 4020 to 12V about 15 years ago. I didn't notice any loss of cranking power with the two 12's connected in parellel vs. the same batterys in series at 24 volts. On average, I gained about 18 months in battery life by getting rid of the generator. You have a lot to gain and nothing to lose by converting it to 12 volt.
R. John Johnson
03-14-2007 12:52:00
I changed over our 4010 years ago and really like it. Cold weather starting is about the same. Since I run a fan in the cab, and sometimes some other electrical loads, I don't have to worry about the generator keeping up with electrical demand.
John
Glen in TX
03-14-2007 12:30:18
YT has a kit in their parts section to give you one idea on cost. You can still put two 12V batteries on it for more cranking power with a high amp alternator and can even get aftermarket wider battery boxes that allow newer style 12V batteries instead of the long narrow ones.
Mike M
03-14-2007 10:17:44
I don't know if the 12 volts will give you good cold starting. It didn't on my 3020. I had a 12V delco starter. If you change look for a nippendenso 12v it may crank better.
msb
03-14-2007 08:33:50
New starter, alternator, some minor changes to the wiring harness and battery cables.You may or may not have to change the fuel gauge.Bob will disagree with me, but I like the change to 12 volts , especially the improved charging at lower engine speeds. Lots of suppliers that sell kits complete with easy to follow instructions.I think maybe they all sell the same kit from a place in Wisconsin? Even so sometimes a bit of blacksmithing needs to be done. If you have to replace a starter then you are most of the way there concerning the cost of the kit.
