Bad spark plug threads in the block
GTKeenum
03-13-2007 18:06:36
The spark plug threads in the block have a line cut in them (Possibly done in the salvage yard when removing from the tractor). The spark plug will screw in freely and tighten up, but I can here compression leaking around it. I have tried a lead washer on the plug and that helps some. I was wondering if anyone had ideas for a more permanent solution. Thanks for any advice, it is always helpful and appreciated.
GTKeenum
03-15-2007 09:23:36
 Re: Bad spark plug threads in the block in reply to GTKeenum, 03-13-2007 18:06:36
Thanks for the advice. As always it was helpful. I have the parts manual and operators manual but there is no substitute for the experience you men have. I will try some of the suggestions this weekend and the more permanent ones when I get a chance to restore it in two years. Thanks again.
johns48jdb
03-14-2007 19:27:06
i don't know about trying to cut new threads in the block unless you've got the head off and can clean all the fillings out good. i'd be affraid to try it without pulling the head. sounds like some of the other suggetions about a tapered plug and a washer might work. i don't know if a copper waher would work better or not. something you might want to try though before going to a lot of trouble. some of the more expirenced guys will chime in and help. just give them time.
Jason Mills
03-14-2007 10:07:52
I was talking to a machinist yesterday about the plug threads. They are straight threads and do not provide the seal. The washer on the spark plug or taper at end of threads is what provides the seal. Maybe you could try a different plug to help seal the leakage. If the cut is to deep then some type of repair may be necessary. Maybe able to use Devcon to fill cut. Make sure it is cleaned good first. You may want to round up a tap to clean threads after repair. Good luck, Jason.
Kemper
03-13-2007 18:49:14
I would try some teflon tape,or if it is something that is restored i would pull the head and take to machine shop and have it fixed.
Paul from MI
03-13-2007 18:17:57
you can check with your local automotive machine shop. There are various types of inserts that can be used. they all involve retapping the hole and putting in a permanent insert or Heli-coil. I would look to a solid type insert because Heli-ciols tend to loosen if used repeatedly. As long as the sealing surface(bottom of the counter bore) is OK, you shouldn't have a problem even if the threads aren't perfect. Good Luck,
Paul
ram ranch
03-13-2007 18:11:02
JB weld? what size thread if 7/8 maybe a adapter to smaller plug?
