7800 fueil; usage
chris meredith
03-13-2007 16:35:59
how bad is a 7800 2 wheel drive tractor on fuel compared to a john deere 4430 i have a4430 and thinking about buying a 7800 2 whelll drive i got a neighbot that sais a 7210 is very easy on fuel any help would be very nice thanks in advance alos any one no of any bad problems with a 7800 thanks
swsaa
07-14-2007 14:08:25
 Re: 7800 fueil; usage in reply to chris meredith, 03-13-2007 16:35:59
sawqww3
WWQQWW
SDA
Allan In NE
03-14-2007 03:35:29
Chris,
Last spring, I borrowed a 7800 4X4 from a friend to work down some heavy sod. At the end of the first day I called him and asked if the fuel guage worked.
Damned thing just absolutely 'sipped' the fuel.
Allan
third party image
ram ranch
03-13-2007 17:51:22
What trans dos the 7800 have? 4430 was good for the day but the torq and tranmissions are far better in the 7000 series.
ram ranch
03-13-2007 17:22:48
I know this is not a 7800 but I have a 7600 smaller motor 414 compared to 466 early 7800, 496 late 7800. But I had our pump rebuilt and the tractor now dynoed 145, and it dosn't use any weres near what my 4430 uses in fuel, I use it (7600) for everything planting, sidedressing, hauling wagons, and everything I would use a 4020 for I get the 7600. It's two wheel drive with a power quad trans.
chris meredith
03-13-2007 17:46:02
 Re: 7800 fueil; usage in reply to ram ranch, 03-13-2007 17:22:48
thanks so much for reply eveone says a 4430 is a hog on fueil i no mines ino the 7800 is suppose to be bigger than 4430 anyone else have any sugeestions on this mater thanks so much
buickanddeere
03-13-2007 18:18:57
 Re: 7800 fuel usage in reply to chris meredith , 03-13-2007 17:46:02
Check the Nebraska test results instead of the options at the local diner. A factory stock 4430 was ok in fuel efficiency. A 4430 turned up and with dirty air filters is a hog. Too many of them around in that condition.
ram ranch
03-13-2007 18:31:17
 Re: 7800 fuel usage in reply to buickanddeere, 03-13-2007 18:18:57
You are correct, ours four years ago wasn't running that good and smoking, turns out the air filter was so bad it colasped the air cleaner cartage. Not good but it's still hard on fuel and it has a smaller fuel tank, so I added anoughter tank to the front just so I could get a full days of work out of it.And with the price of fuel who would not want the fuel economy?
