john deere b not shifting
jonathan s
03-13-2007 16:19:42
hey guys, i have this 1950 john deere b. the problem is that when shifting sometimes it wont grap the gears on the left side of the tractor. it always grabs the right but osmetimes not the left. if anyone could help me it would be very much appreciated. thanks again jonathan s
Pappy
03-13-2007 22:17:31
 Re: john deere b not shifting in reply to jonathan s, 03-13-2007 16:19:42
Plan to pull the top cover off the transmission and take a look at the shifter mechanism. It might be a worn shifter gate or worn shift lever. Check to see if the hi-lo shift pawl is tight on the shaft and is not bent. Look inside to see if your hi-lo gear is actually shifting from right to left. See if there is any play in that shaft when the gear is in the left position. Could have a bearing problem on the right side of the splined shaft.
all inside??
03-13-2007 16:53:43
what gears are on the left side?? I thought all the gears are INSIDE!!!!
caseih
03-13-2007 19:46:07
 Re: john deere b not shifting in reply to all inside??, 03-13-2007 16:53:43
smart a$$$$.
