4020 vs 4620
nspec
03-13-2007 12:11:05
Could someone be so kind as to explain briefly the major differences in the 4020 vs the 4620? I"m talking diesel/powershift on both. Looks to me like same bore, stroke, and displacement, no? We put a turbo on a 4020 years ago and besides a few more oil leaks, ran like a beast for many years. Lots more power. In 20 years, never touched the powershift transmission - flawless.
Thanks!
nspec
03-13-2007 16:41:36
 Re: 4020 vs 4620 in reply to nspec, 03-13-2007 12:11:05
thanks guys. that's what I was looking for.
mike w J
03-13-2007 16:23:55
5000 + lbs not as handy in tight places . 4620 pulled 14471 lbs at 2.22 mph 4020 pulled 11104 lbs at 2.33 mph. But having owned both A 4020 won't even come close to doing the same work in the field .
G/MAN
03-13-2007 13:41:15
4620s are bigger from front to back and top to bottom. Different steering arrangement and much larger front axles. Everything is much bigger and heavier behind the engine - trans, finals, differential, hitch, etc. Turboed and aftercooled version of 404 engine with a front-mounted injection pump rather than the mid-mounted pump on the 4020. Same bore and stroke but that's about it as far as the engines go.
Glen in TX
03-13-2007 13:11:17
4620 was test rated at 135 hp vs. 4020 95 hp. 4620 had a 404 intercooled "turbo built" engine utilizing intercooler technology for denser air charge and more power not just a add on turbo. The 4620 only came with 1000 rpm PTO and final drives and frame were stronger and different than 4020. More oil capacity in engine, bigger radiator and fan, redesigned block for more oil flow. 4620 made 1971-72 replaced earlier similar 122 hp 4520 made 1969-70.
