There's less energy per gallon of LP than of gasoline. The 3020 and 4020 gas were nearly the poorest of fuel economy tractors of that time period. Something like 7.9 hp-hr per gallon of gasoline. So getting 60 hp takes 7.5 gallons per hour. I don't remember the Nebraska tractor test numbers for 4020 or 3020 propane. Be sure the timing is advanced to specification and that the centrifugal advance is working. Gas and LP engines need more advance at part throttle, but our tractors don't do that. Be sure the choke is opening all the way. My gas 4020 had that problem because the sheath of the choke wire wasn't anchored near the carburetor and it would only push the choke half way open. Be sure the air filter isn't plugged. Be sure the precleaner top is domed up, not down. Mine was dome down and acted as a partial choke. Be sure the plugs are good. LP takes a lot colder plug than gasoline. Stay away from Champion plugs. Be sure the plug wires are copper, not carbon. Be sure the thermostats are good. You need engine heat to vaporize the fuel in the vaporizer. The carburetor will pass a lot more fuel in liquid form than in vapor form. Droplets in the vapor make it run rich and inefficient. Tank in half a day while working hard is not way out of line, but these few details may help a little. Gerald J.
