3020 JD 12 volt neg ground / electronic ignition H
Micker
03-13-2007 07:04:01
I have a JD 3020 68000 and after it has a 12 volt negative ground system using a generator and regulator charging system. It has an igniter electronic ignition system. The problem is it starts fine and runs great but only for 30-50 minutes and quits. After about 3 hrs it will start again. Battery has 12.4 volts the charging system puts out 13-14.7 volts. New coil with good spark.BUT the coil gets so hot you can"t touch it when it quits. Is there a resistor wire that is not wired right or wrong coil. Coil has 1.5 ohms resistance.Help
Gerald J.
03-13-2007 08:45:44
 Re: 3020 JD 12 volt neg ground / electronic igniti in reply to Micker, 03-13-2007 07:04:01
third party image
There is a resistor, part of the ignition switch or its wiring. It gets shunted out of the circuit by a special terminal on the starter solenoid. That way with a 6 volt coil it starts with 9 or 10 volts on the coil when the starter is pulling the battery down, but runs with about 6 volts on the coil. The resistor wire or ignition switch probably have failed. I know my gas 4020 has the ceramic resistor mounted next to the coil. That white rectangle in this picture. At the right edge.
You probably don't need that start provision with the electronic ignition, but you don't need to beat up on that 6 volt coil with 12 volts. And now that its failing when hot, it probably will never run long, even if kept cooler by running at 6 volts. You need a new coil, and the proper coil.
The proper coil is probably a 12 volt coil made for use without an external resistor. They do may special hot coils for use with electronic ignitions. At a top speed of 2500 RPM, super hot ignition isn't going to get super tractor performance, though it might make it run better with a lean mixture for better fuel economy. Proper timing for part throttle running would do more for fuel economy, but its not handy to do.
Gerald J.
Micker
03-13-2007 13:24:18
 Re: 3020 JD 12 volt neg ground / electronic igniti in reply to Gerald J., 03-13-2007 08:45:44
I added a 1.8 ballast resistor . A hot wire off the key switch and the red wire off the electronic module to one side of resistor and ran a wire from the other side of the resistor to the positive side of the coil. It worked for 20 minutes.
Gerald J.
03-13-2007 14:05:49
 Re: 3020 JD 12 volt neg ground / electronic igniti in reply to Micker, 03-13-2007 13:24:18
Once you've driven the coil to failure, its almost sure to repeat the failure as soon as it warms up.
I'd go for 3.6 ohms, a value more likely to be equal to the coil's resistance which is what you want when apply twice the voltage. 1.8 ohms seems a little small. I don't know what value is on my 4020, it just works.
Some of the ignition wiring had been reworked with a Scotchtap that got intermittant and made me hot wire it to finish hay making one summer. I took all the Scotchtaps out of the wiring and it has been a lot more reliable. But I didn't detect that was heat sensitive, it was just open most of the time.
Working a while and then failing and then working again a while when cooled off is characteristic of a coil failure. It has lots of wire and so lots of thermal inertia.
Gerald J.
Micker
03-14-2007 09:23:03
 Re: 3020 JD 12 volt neg ground / electronic igniti in reply to Gerald J., 03-13-2007 14:05:49
With the right coil things work like they should. I installed a new coil (the right one for electronic ignition). Thank you for helping me.
John T
03-13-2007 07:59:20
Micker, it sounds like the elec ignition switch is okay n doin its job, buttttt ttttt the coil (since its primary resistance is 1.5 ohms) is a 6 volt whereby it overheats n shuts down. Since the battery voltage is 12 volts, the coil should be a full true 12 volt rated unit (around 3 ohms primary resistance) OR ELSE if its only a 6 volt coil (1.5 ohms as you describe) you can get by adding an external series (around 1.5 to 1.75 ohms) Ballast Resistor wired After the ignition switch and Before the coil. That way the coils current and resulting temperature is within its limits n it wont overheat. It should be a tad warm but NOT so hot you can barely lay your hand on it.
NOTE to get the most bang for the buck that elec ignition can offer, I suggest you use a High Energy High Voltage 12 volt coil that matches up with the elec switches specs (check with the vendor for their high energy coil recommendations to match your switch) and run a wider plug gap. That way you get a higher energy wider hotter spark wooooo o hooooo oo. The spark energy is still improved using an elec switch even with a stock coil, however, to utilize all the benefits that switch has to offer I would couple it up with a 12 volt high energy coil that matches the switches current ratings.
There may be another issue depending on the ignition system, it may be equipped with a start by pass system which (if it had a 6 volt coil on a 12 volt tractor) delivered full unballasted battery voltage direct to the coil ONLY while cranking after which time the coil current n voltage was reduced via an inline ballast resistor. Such can be done with solenoids or switches or even without any switch using an in line thermistor, a heat compesating variable resistor that wired ahead of the coil, so there was batetry voltage to the coil initially but resistance increased afetr warm up. ACTUALLY if you get a 12 volt high energy coil and with that elec ignition, you can get by fine without having to worry about any by pass, she ought to fire right up summer or winter.
EITHER add a series external ballast resistor to that 6 volt coil (to reduce current n overheating), or get a full true 12 votl coil (NO ballast used) and better yet a high energy coil that matches up with your switches rating..... ..
Inquire about the Pertronix Flame Thrower Coil !!!!! !!!!!
John T
Micker
03-14-2007 09:16:33
 Re: 3020 JD 12 volt neg ground / electronic igniti in reply to John T, 03-13-2007 07:59:20
Installed the new Flame Thrower HP coil and the tractor runs great. Thank you for your help.
Micker
03-13-2007 13:27:50
I added the resistor and it ran about 20 min.
I'll be getting a new 12 v Flame thrower.
John T
03-13-2007 14:45:38
 Re: 3020 JD 12 volt neg ground / electronic igniti in reply to Micker, 03-13-2007 13:27:50
I like that plan, you will deliver more spark energy across the plug gap (set it wider) n get the most bang for the buck from the elec switch and know the coil n switch are a match provided Pertronix says so. The old coil may be damaged from overheating making it fail even when you added ballast.
John T
