Clutch Lever movement
Timber Farms
03-13-2007 07:00:55
I have a 44 B and the clutch level does not move forward very far. I removed the lever and the plate that covers the engagement equipment. Looks like a half circle metal ring should insert as the level is pushed. Is there some trick to position this ring??
Mike n Mo
03-13-2007 12:34:29
 Re: Clutch Lever movement in reply to Timber Farms, 03-13-2007 07:00:55
The "half circle metal ring" should slide into a corresponding groove on the clutch sleeve. If it were installed to the left (flywheel) side it will have very little movement. Sometimes a little tricky until you've done it a few times. Mike
