j d hydraulic experts
5020s rock
03-13-2007 01:06:38
hi--can a guy replace jds service control
valve with a one spool control valve similiar to a log splitter? this valve would have 30 gpm max.,
adjustable psi from 1500 to 3000,relief pressure
of 1500 and no detent. also, what does the term
floating refer to?..... i am tired of chasing used
valves and remotes. thanks
matthies
03-13-2007 19:43:08
 Re: j d hydraulic experts in reply to 5020s rock, 03-13-2007 01:06:38
Have you had the seats ground and valves adjusted on the scv's? Or doesn't the dealer mess with them? Early or late model? chris
5020s rock
03-13-2007 13:08:42
hi--thanks for the input. it is for a
4020. good point about the relief, i should know
that from work????? more input please.
Mike M
03-14-2007 06:44:47
 Re: j d hydraulic experts in reply to 5020s rock, 03-13-2007 13:08:42
Closed center vavle needed for sure. On that 4020 you can tap into the hyd.pressure over by the brake pedals and get a special tee. I think you can find it in the parts book for 148-158 loaders. Return to a ported filter cover or where the other pipes return on the LH side like an industrial version does.
Mike M
03-13-2007 07:32:51
What tractor are you putting it on ? Because if it has closed center hyd. your going to also need a valve that can be set for closed center. I guess the float would have a detent that the lever snaps into so the implement can float. This is usually used on loader valves and is helpfull when back dragging.
low budget
03-13-2007 09:40:48
 Re: j d hydraulic experts in reply to Mike M, 03-13-2007 07:32:51
Just wanted to add some info. Must be closed center valve or convertable. Relief pressure must be set higher than system standby pressure or the oil will bypass constantly and overheat your hydraulic system.
