Camshaft Wear on 36 B
CalJim
03-12-2007 20:56:21
Motor is totally rebuilt, except for camshaft.
Anyone know how to tell if cam lobes are worn?
Don't recall ever seeing specs for this, even
on the newer B's. Thank You CalJim
Sam in MN.
03-13-2007 13:30:19
 Re: Camshaft Wear on 36 B in reply to CalJim, 03-12-2007 20:56:21
I have been working on a total rebuild of my 48 A, pulled the Cam and followers and all looked good at that time. but what the heck, for about $180 I had all reground and what a difference it made.
Once you have it tore down that far, spend the money now to have the Cam and a four followers brought back to spec. Also check the cam bearing on the left side, as that one usually fails first and is a bear to change later. I did both bearings and races.
Beleive me, it's a whole lot easier now than later to fix. Plus if you did a valve job, why have new valves run by a 70 year old cam?
F-I-T
03-13-2007 11:45:32
You might ask for specs from Robert's Carburetor. They re-grind cams, so they must have the numbers for a stock cam.
If you had the lift and duration, a mini-degree wheel, a test stand for a dial indicator, and a decent set of gauge centers to mount it on, should not be too much trouble to check out. That's how I laid out the cam on my 70D. In fact, I had access to a 30" optical comparator so you could look at form wear as well. If you can just get a number for the total lift from the master circle dimension, you can pretty much determine of you had much wear at all, and then that might steer you towards whether you have to re-grind or not.
Frank
