Another wheel question
JBIFF76
03-12-2007 19:11:34
I just bought a 1938 B with cutoff rear wheels. I have a set of B695R cast rears that I want to put on it. The B695R centers I want to put on it have 9"-38" rims on them. J.R Hobbs Unstyled Letter Series book says 36" rims. My question is, What size rim/tire belongs on it?
Duane Larson
03-12-2007 20:00:34
 Re: Another wheel question in reply to JBIFF76, 03-12-2007 19:11:34
JBIFF76,
It would have come with a 6.00S-36 conventional rim, as wide base tires were not available in 1938 - and there were no 38" conventional tires. The tire size would have been either 7.50-36 or 9.00-36. Present day sizes which most folks use are either wide-base 9.5-36 or 11.2-36, the latter looking a bit big to me, but you should look at some unsB's to see what you like. I'm not sure how available that rim is, but you might check with Detwiler as that is the rim he rolls to use on his new round spoke wheels.
JBIFF76
03-12-2007 20:06:27
 Re: Another wheel question in reply to Duane Larson, 03-12-2007 20:00:34
So, the B695R cast center wheel would take both a 36" and a 38" rim? The tractor has 11.2-38 tires on cuttoffs now and does not look bad.
Duane Larson
03-13-2007 06:31:02
 Re: Another wheel question in reply to JBIFF76, 03-12-2007 20:06:27
Yes - the cast center is nominally 34" in diameter, and 38" deep well rims should work but I haven't done it. Your centers with 36" wheels are less common than round spoke wheels and you might want to consider that before you go to 38".
JBIFF76
03-13-2007 19:11:53
 Re: Another wheel question in reply to Duane Larson, 03-13-2007 06:31:02
Thanks for the information. I knew there were less of the cast rears than rounds. But people still pay the BUCKS for rounds. I found these wheels fairly cheap with the intentions of finding a B on cutoffs and switching but I didn't realize they had 38" rims on them until now. Is there only a certain 36" rim that will work on the 695R center. If they are somewhat findable/affordable I would be interested. Thanks again, Jon B.
