john deere b no fire
jonathan s
03-12-2007 17:44:08
hey guys i need some help with my b again. the problem is that there isn"t a very big spark at the points. i put a brand new coil, condensor, points, cap, and rotor on it. i even ran a wire from the battery to where the power goes into the distributer.(xb) i was wondering if anyone of you guys could tell me what i could do to get enough spark to make it run? any input will be very much apreciated. thanks again, jonathan s
Marvscheb
03-14-2007 15:45:42
 Re: john deere b no fire in reply to jonathan s, 03-12-2007 17:44:08
Johnathon, Measure spark at the spark plug need 3/8 inch or more. I prefer 1/2 inch If dont have it there go back to mag /distributor spark plug wire outlets. If you dont have it there ---Mag can be anything from weak magnets to a poor connection. Always consider new condenser and new points and good rotor and good cap. I worked on many John Deeres and still can think of no good reason to change things as in from 6 volt to 12 volt. Maybe you can get a little better starter performance but thats about it. If you have 6 volt do your homework get everything restored and enjoy the machine If you did convert research everything to be able to step by step set it up for peak performance. One other option is to get a wico "X" magneto in restored or new condition and time properely your troubles are over for a long time. More questions E-mail me Ray
Glen in TX
03-12-2007 20:58:51
That Wico XB battery distributor if that's what you have on it is a 6V only system when setup with original coil and if hooked up to 12V and didn't use a step down resistor to 6V on it you fried the new coil. Something else on the XB dist. is make sure you have the right condenser for it and have a spring under it to ground it properly. If you want a copy of XB service manual or parts list send me a email. If it's a Wico XH magneto and not battery ignition distributor and you hooked a battery to it you fried the coil also.
XB Distributor third party image
XH Mag
third party image
Paul from MI
03-12-2007 18:31:12
Not very familiar with Wico XB, but do you have a 6V coil(assuming your B is still 6V?). Also might clean the points. I usually use a dollar bill, the paper in paper money seems to be just abrasive enouigh to clean oxide from points. If you think they"re real dirty, use $5. Is the distributor worn si that the points aren"t opening consistently? Might check the bearings on the shaft. Hope this helps, there are others here who can give you better advice.
Paul
