B Power Lift leaking into Trans
alex-41JDb
03-12-2007 15:02:47
When I started working on my 41B I changed all the fluids including the power lift. When I went to drain the power lift it was nearly empty which should have been a hint. Anyways the power lift was filled and it worked. A few days later I went to check the level of the trans oil and a ton of oil bubbled out about equivalent of what was in the power lift. Is my power lift leaking down into my trans or what? What is causing this and whats the fix. Thanks Al
Mike M
03-13-2007 06:54:25
 Re: B Power Lift leaking into Trans in reply to alex-41JDb, 03-12-2007 15:02:47
There are a couple of places that can leak in. The most common one is the gasket for the rockshaft cylinder. It could also leak in around the pto shaft and I think there is maybe a metal plug like a freeze plug inside there too. Either way the backs going to have to come off.
