3020 injector pump
JR in TX
03-12-2007 13:51:45
I was disking with this tractor this weekend and it started losing power gradually and the rpms dropped off till it finally died and would not start. I have had it only had it a month or so and don't know the maintenance history. So I changed the fuel filter and it was full of black stuff. I bled the filter and the the tractor started but would not get above idle. So my operators manual said loosen the injector lines. Well I did that and one time it got to around 1500 rpms then died down. So I took two injector lines all the way apart and looked at the flow, it was kind of a sporatic spit. This my first time bleeding a diesel system. I don't think I should have taken those two lines apart. Now it will start up strong and then miss and chug for about 30 seconds and die. It will start right back up and do the same thing. I have good flow to the injector pump. Today I'm going back to field after work and just crack the line barely open. Is that the right way? Do you think my injector pump is bad? what should the flow look like at the injector lines?
JR in TX
03-13-2007 06:12:04
 Re: 3020 injector pump in reply to JR in TX, 03-12-2007 13:51:45
Thanks for the info, I didn't get to read any replies before I worked on it yesterday.It is running better, it doesn't die but it speeds up slowly and not to full throttle. Now I noticed I have any injector leaking pretty bad. I keep ya'll posted, thanks.
Tx Jim
03-13-2007 04:53:45
JR,you have Algae in your fuel tank and need to add Formaldehyde or fuel additive as prviously stated to kill Algae. Check tank for water as this contributes to Algae growth. There's a drain in bottom of tank. Remove fuel return line at inj. pump and fitting that return line fastens to at pump. Check fitting for blockage as it has a glass check ball built in to it that can get stuck. Try running tractor with line loose for short period. Tx Jim
dwag
03-12-2007 18:06:38
The black stuff in fuel filter is a fungus. Your fuel supplier will have a treatment for it. Take small rectangular plate, held with 2 small screws off side of inj pump and look for rubber chunks behind plate. Either gov cage is bad (rubber chunks) or fungus has restricted fuel return orifice at return fitting on top of pump.
Floyd TN
03-12-2007 18:04:35
Had a 3020 last year with the same problem.. Had to rebuild the injector pump...
Not sure as to the cause, but I"d say the tractor was run with a dirty filter to long or just wear in the pump..
On these older model JD"s it doesn"t take much dirty fuel to eat up the seals and wear the shafts.
buickanddeere
03-12-2007 16:49:09
Flow in the injection lines is supposed to be spurts of very high pressure fuel at 2250+psi. Should you be sprayed with a stream of fuel from a small orfice. The fuel will either peel off skin or be injected deep into the tissues. We are talking loss of digits or limbs here or a nasty infection/irritation at best. Have you checked the lines right back to the tank and how much flow & pressure is there from the mechanical pump which feeds the filter.
