2040 DRAFT
Mnailt
03-12-2007 12:18:29
I have a 1977 Model 2040 with loader. The three point draft will only work when you operate the levers on the loader and the draft lever is up.
seem like their is something plugged up and am not getting enough preassure to the draft arms. any help for a newbe. Mark
Tx Jim
03-13-2007 05:06:03
 open or closed-center hyd???? in reply to Mnailt, 03-12-2007 12:18:29
Mark,do you operate loader with ind. valve on loader or scv's on tractor? If ind. valve then I think you have an open-center valve or blown o-ring in ind. valve. If ind.valve controlled try disconnecting pressure feed line to valve and see if 3pt acts different. I just remembered that early 2040's came from factory as open-centered hyd's so look in front of radiator at hyd. pump,is pump fairly small or large with plugs around it? Tx Jim
