4630 Clutch
FarmB0Y
03-12-2007 07:01:44
Hi I was just wondering if anyone could give me some direction we have a 4630 and we are having a hard time pulling the tractor out of gear. We are assuming that it is the clutch but is it possible that it could be the valve? Or are we off the mark.
Also if anyone has any hints or tips on splitting it that would be greatly appreciated.
Thanks
FarmB0y
03-12-2007 07:25:46
 Re: 4630 Clutch in reply to FarmB0Y, 03-12-2007 07:01:44
Yes it is hard to get in and out of gear. There was a little bit of a noise during spring work last year, however it was shifting without any problems.
We have used it with a blade to do some brush work and pushing snow, this problem only showed up about a month ago. We have had this tractor for 5 years with no problems.
The reason I was wondering about the valve is we just bought a 4430 and it looks like the clutch valve was removed form that tractor (paint is missing ect.)
Bob
03-12-2007 07:16:22
Is it tough to get it INTO gear, too?
There is a "lube reduction valve" that cuts back on the amount of oil sprayed into the clutch plates for cooling/lube when the clutch pedal is fully depressed.
That might be something to check.
Do you suspect the clutch has ever been abused (slipped,burned), or that the wrong oil could have been used in the rear end/hydraulics?
If it comes to that, it's a HEAVY tractor to split... don't attempt without experience, AND a Genuine DEERE shop manual.
Before splitting, withdraw the transmission pump driveshaft out of the back of the tractor.
