JD 4400 (compact tractor) Fuel Solenoid
twelch24
03-12-2007 03:12:54
I realize this is supposed to be classic tractors, but I don't know where else to ask. Here goes :)
I have a 4400 compact tractor on which the fuel shutoff solenoid has failed. JD wants $112 for the part, so I'd like to be sure there's not some reason for it to have failed. Is this a common problem on these tractors? I have noticed that there's some oil that gets into the solenoid itself through the injector pump. Should I be worried about this?
Thanks,
Tim
Joe M(GA)
03-12-2007 18:54:11
 Re: JD 4400 (compact tractor) Fuel Solenoid in reply to twelch24, 03-12-2007 03:12:54
Tim, it has been known to fail, usally because of the following-
Solution Number: 58414
Solution Summary: Engine spins over but fails to start.
Publication Date: Jun 27 2006
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom : The Engine cranks but fails to start. Oil is found in the fuel shutoff solenoid.
Problem or Situation : It is normal for engine oil to get behind the plunger and the oil should be able to come out before the solenoid pull in winding times out. The R2 thermistor wired behind the K3 relay may not be working correctly causing the pull in winding of the solenoid to drop out to quickly or not pull in at all.
Solution : Test power going to the white wire on the main harness side of the fuel solenoid. Voltage should be present when the key is initially switched to the run position, but, should drop off after a few seconds. The period of time that the solenoid gets power will change depending on the temperature of the thermistor.
If the 1 second peak amperage draw is less than 20 amps.
Inspect the R2 variable thermistor which is located behind the K3 fuel relay and replace as required with part number LVU10323. This variable thermistor allows the pull in winding of the fuel solenoid to have power initially to be able to pull the solenoid in and allow fuel to flow to the pump. After 1 second this thermistor should drop current flow to the white wire going to the solenoid and keep the solenoid from melting. Peak current flow should be between 20 to 35 Amps during the 1 second time period.
Additional Information : One Dealer tested current at the thermistor and found that within a few milliseconds the current would only get up to 6 A and then drop off. 6 A will not be enough current to pull in the solenoid in some instances.
4700, 4200, 4600, 4400, 4300, 4500
Lake City
05-06-2007 10:11:09
 Re: JD 4400 (compact tractor) Fuel Solenoid in reply to Joe M(GA), 03-12-2007 18:54:11
I purchased this tractor last October and it appeared that the solenoid had been replace just recently.
I had the same problem with my 4400 shortly after I bought it and had the solenoid replaced. It worked fine for 40 hours and now it is acting up again. I don't think it is the solenoid, it could however be the thermistor.
twelch24
03-12-2007 19:24:19
I'll check that out in the morning. I think this particular model is one of the worst things ever created by deere, with its plastic hood and body. Almost every panel on the thing is broken. Both lift arms have broken the axle housing (great idea..aluminum housings to hold a 3ph).. the list goes on and on.
I've had the tractor fail to start before, and upon removing the fuel solenoid oil poured out. I cleaned it as best I could and reinstalled it, and it cranked right up. I assumed the oil was the culprit, but it could well have been the thermistor too. I'm going to have to put a current meter on it.
Thanks,
Tim
