52 B Water pump rebuild
Ron Rod
03-11-2007 19:18:41
I'm about to install the seal in a B water pump and can't see how to hold the alignment of the little side wings on the carbon seal face with the slots in the impeller so it doesn't break when the impeller is pressed on. Seems like a very high risk procedure since it's impossible to see the alignment or lack therof. Any one solved this problem or have any tips that increase the chance of success. Thanks very much.
Ron
Mike M
03-12-2007 05:22:33
 Re: 52 B Water pump rebuild in reply to Ron Rod, 03-11-2007 19:18:41
I'm not sure how the set up your working on is ? but is it possible to stick the parts in question up in the impeller first maybe with some grease or vaseline ? then press it.
RonRod
03-12-2007 06:20:47
 Re: 52 B Water pump rebuild in reply to Mike M, 03-12-2007 05:22:33
There is a fairly major spring between the seal carbon face piece and the impeller so it doesn't really touch the impeller. Perhaps I could vaseline it to the mating face in the pump casing.
Still seems like a blind press on a very fragile part though.
Ron
Mike M
03-12-2007 08:13:48
 Re: 52 B Water pump rebuild in reply to RonRod, 03-12-2007 06:20:47
I guess on the plus side if you can call it that ? if you put it together and it leaks you know why. It didn't line up and/or cracked. I think I did a pump on a later JD that had something like that. And I may of even had to use a couple of seals til I got it lined up without breaking.
