50 B smoke
jd60wh
03-11-2007 18:56:57
Ok I have a "50 B that runs good but has a smoke problem. It will smoke a bit out the stack on start up but quits after a minute or so. After it warms up I get a steady cloud of smoke coming from the belt pulley area. I can take the oil filler cap off and get a white cloud from the crankcase so it is not the clutch. I checked the vent pump and it has pleanty of suction. The smoke does not smell real oily. Any suggestions. This is a play tractor and I do not want to sink a ton of money into it. Maybe a set of rings? But if it needs rings wouldn"t it smoke out of the stack a whole bunch? I am pretty baffled!
Mike M
03-12-2007 05:28:55
 Re: 50 B smoke in reply to jd60wh, 03-11-2007 18:56:57
It kinda just sounds like a worn out engine to me ? Lots of blow by plus worn rod/main bearings makeing a knock when warm. And it sounds like to fix it will get expensive.
Rings may help some and if the rods are still the adjustable type you may help it some with an adjustment on the rods and mains. But don't be surprized if it needs bored and the crank reground too.
jd60wh
03-11-2007 19:24:22
There is a slight knock when it gets warm....I have good oil pressure but it falls off just a bit when it gets warmer. How did you go about fixing it? Blowing out the lines in the case? or replacing the bearings or both?
Sam in MN.
03-11-2007 19:13:06
Holly Smoke.....
I had the same problem with my 48 A and it turned out to be a hot connecting rod journal bearing, that was buring the oil. Pure white smoke.
Check your oil pressure and if that is OK, then you may have a plugged oil line to one of the main bearings.
Don't run it any more than necessary! If it's that hot, it is not normal and most likely a hot bearing. Any knocking noise from the crankcase?
