Roy, I agree with Dale there, it originally was top to left and bottom to right, however things can get changed over the years for sure. If the wires are in reverse but the timing is otherwise okay, she will pop n bark and backfire something awful, but in which case a simple top n bottom wire reversal will make her run. That mag (unlike all mags) fires its plugs on BOTH the pistons Top Dead Centers, power or exhaust strokes, and runs the same speed as the crank (its not a gear reduction drive mag), which is why if the mag were installed into the governor shafts female drive cog 180 out from original, a top n bottom wire reveresal can make her run. I set the initial start timing so the mag snaps to fire just when the Left Hand Impulse timing mark on the flywheel is in the 3 o clock position in line with a flat mark on the tractors side. If she fires too early before that, the flywheel can kick backwards. To adjust that, loosen the mags mounting bolts and turn it CCW to advance or CW to retard till she does as I say above. Hope this helps and answers your question, if not, hopefully others can add more to this. Post back or e mail [email protected] with any more questions. Good Luck n God Bless ya Roy, John T Nordhoff
