Clearance between Rod/Crank on JD B
txasylum
03-11-2007 13:29:38
I'm reading my manual and it says "connecting rod bearing oil clearance - .003", "connecting rod shim thickness - .003".
Am I misunderstanding this or is there that much play between the rod and the crankshaft?
Also, the manual says the piston is stamped "top", but I can't make anything out on my pistions. HOw important is it that the top is on top? How can I be sure I have the "top".
Oh, I didn't take this apart. I bought it this way, so I'm trying to put it back together.
Thanks
Bob
Farmboy169
03-11-2007 16:32:14
 Re: Clearance between Rod/Crank on JD B in reply to txasylum, 03-11-2007 13:29:38
I'm not sure on the clearance question, but the piston should say "TOP" on the edge of the skirt, or bottom of piston, that's were it was on the piston's in my D.
P Browning
03-11-2007 16:29:23
Operating or running clearance of 0.003-inch is the call-out for this slow running engine, and yes -- an oil film will generally fill this void. Shim thickness of 0.003-inch is a convenient dimension -- Here's how this works out with what is commonly called the Trial & Error method:
"Install connecting rod with shim stacks and torque. If there is no binding or halting in crank rotation, remove 1 shim (top and bottom) and repeat until binding occurs. If there is binding, add 1 shim (top and bottom) and repeat. If it spins freely, you are good to go!"
As for pistons, here is the story:
"Piston Orientation -- There IS a top-side and a bottom-side to JD pistons. Most of them will be marked "TOP". If yours aren't so marked, or you just can't find the mark, then examine the oil ring groove. You will find a short series of holes on one side of the piston that extends half way around the oil ring groove. Orient the piston with these holes UP."
These are two quotes taken from the John Deere Model "H" Restoration Guide, 2nd Edition.
