B oil leak
teddy52food
03-11-2007 08:10:50
I have a 44 armstrong start B. Oil is leaking from the back side of the flywheel. It doesn't seem to run down the casting. Is there a seal to be replaced, or just the slinger? How to correct it?
teddy52food
03-12-2007 10:26:39
 Re: B oil leak in reply to teddy52food, 03-11-2007 08:10:50
Well I found the cork seal you talked about & it was hard & broke when I tried to get it out of the slinger. I looked in my assortment of o rings, but didn't find anything that would work. I then looked in some leftover automatic transmission kits & found seals from a c4 Ford that fit. I got it all back together but didn't start it yet. I think it will be ok. Thanks for the tip. The main bearing seems tight. It has good oil pressure even at a hot idle.
DickD
03-11-2007 08:36:25
There is a very delicate cork seal that goes in behind the flywheel spacer. If you are going to replace it, it might be a good idea to check your main bearing clearance, and see that it is what it should be, and isn't the culprit that is causing your seal to leak. Be CAREFUL when installing the new seal. It is very easy to destroy it. Good Luck! Dick
