JD 1010 anti sway bars
Rich McGinnis
03-10-2007 19:14:13
Looking for information on how to stop the sway in the link arms for my John Deere 1010. Are there link arms or chains for this model?
Loren NC
03-16-2007 04:13:29
 Re: JD 1010 anti sway bars in reply to Rich McGinnis, 03-10-2007 19:14:13
My 1010 has a factory pin below the axle on the left side for hanging the sway bar. I mounted another one on the right side so I can use either or both. The key, as someone else pointed out, is to be sure they line up with the inside pivot points of the lift arms. Otherwise you will have problems with breaking things whenever you raise or lower the arms.
For the sway bars themselves, I used one turn-buckle arm and one flat bar I bought from TSC.
Ray
03-11-2007 10:40:47
There's a factory arm that fastens below the pto and an arm that goes to the top of the 3pt arm of the plow or whatever your using on 1010 models.The 1010 was the only model to use this system.
Henry M
03-11-2007 06:50:34
Rinus
If you look at some commercial applications you will find that the secret to raising and lowering without having problems with sway bars is that the front pivot has to be lined up laterally with the front pivot of the lifting arm. Then you don't have the changing of symetry problems as the lifting arm goes up and down.
buickanddeere
03-11-2007 04:43:32
Sway bars work better than sway chains. A bit of fabrication will make them bolt onto the side of the drawbar brackets.
rinus biemans
03-10-2007 20:02:18
i have solved this problem by means of chains and turnbuckles but you have to adjust them for each heigth and watch the effect when you raise or lower the tph from that position . It does not take much and you break something
