1948 model A powertrol problem
hassel
03-10-2007 13:53:13
I use this tractor during hay season to pull my haybine.Last fall it got to the point where it wouldnt raise the implement I cleaned the unit this fall and removed the original fittings and replaced them with pioneer quick connects I put a guage on the lift side and have 950 lbs of pressure. when I hooked up to the haybine it will lift it but when I let off the lever it drops back down any Ideas? hay season is around the corner
F-I-T
03-11-2007 11:56:05
 Re: 1948 model A powertrol problem in reply to hassel, 03-10-2007 13:53:13
If the oil is not leaking into the rear end as it can when the internal cylinder gasket to rear cover is blown, and you are lifting but not maintaining the load in position on the rockshaft, then there's a HIGH likehood that the leather or o-ring, however yours is configured, on the lift piston as being the fault. Of course your problem involves the remote cylinder, so the lift cylinder is out of the picture.
You need to test whether the Powr-Trol unit can trap the oil inside properly, between the check valves and the remote cylinder. There is a procedure I use for that. Here it is, briefly:
First you'll have to determine your leak source. It could be a dirty or otherwise flawed check valve in the P-trol box. To determine if it is the cylinder or the check valve(s), raise the load to high limit, and shut down the tractor. Locate the throttle valve cap nut (long hex nut on the lower rear of the P-trol box) and the Metering screw (located on the tractor left side of the P-trol box). Now you need to turn both the metering screw and the throttle screw out until they seat. This will effectively lock the oil in the P-trol box so if it still drifts down, it's leaking past the cylinder piston or some other internal o-ring. If it stays put, the leak is in the Powr-Trol control box, meaning check valves, etc..
To set the metering and throttle screws back to where they should be, remember the metering screw determines the speed that the system slow raises, and the throttle screw determines the fast drop speed. This is to be adjusted based on different weights of implements you might use. All of this is in your operator's manual, BTW. "In" increases oil flow through either screw, and "Out" decreases to the point of no oil flow allowed.
If you are not losing oil, meaning the oil is not leaking out externally or internally (evidenced by the rising oil level in the rear end and the need to add oil to the P-trol) then suspect areas are the piston seal (for "lift drift"), o-rings on the plugs, or the actual remote cylinder on the implement. You could also have a crack somewhere, or a sand hole, though they usually don't wait 60 years to show up!
Frank
Glen in TX
03-10-2007 15:14:06
From SM2011 hydraulics trouble shooting:
Won't stay raised? >O-rings leaking at lower hose adapter- replace.
>Check valves leaking- replace.
>Piston ring leaking-replace.
>Sand hole in cylinder casting-repair or replace.
>Gasket leaking btween end cap cylinder housing- replace.
Control lever not locking?
>Release valve stuck-remove & clean.
>Bleed hole plugged-remove & clean.
>Worn cam- replace.
