I need a 320 wiring diagram
Ray
03-10-2007 11:11:26
Anyone have a wiring diagram for a JD 320 tractor
that they could email or fax me? Someone removed
the fuse holder in the dash and added a toggle
switch in line with the ignition switch.I'd like to get it back to the original.Thanks.
Gerald J.
03-11-2007 09:34:58
 Re: I need a 320 wiring diagram in reply to Ray, 03-10-2007 11:11:26
There's one for the 440 in the I&T manual. (JD-15). It says they are similar for all the models covered (40,320,330,420,430,440) except some had key switch inseries with that fuse holder, some didn't and some didn't have the electric oil gauge.
Just take out the toggle switch, and put the fuse holder in its place in the circuit and in the hole.
Everything is switched by the auxiliary relay (L terminal) in the voltage regulator and the main rotary switch. Does your voltage regulator have four terminals? Maybe that's been replaced with a 3 three terminal regulator and it doesn't shut off the loads.
Gerald J.
Glen in TX
03-10-2007 15:03:33
Diagram for the 40 and another for 420 & 430 are shown in SM2029 but nothing specific for wiring is shown for the 320, 330, so unless someone has a later bulletin on one probably close enough.
Maark
03-10-2007 13:20:45
You can download a diagram for a Model 40 at www.jd40.com. should be the same wiring diagram as a 320.
Ray
03-10-2007 16:05:54
 Re: I need a 320 wiring diagram in reply to Maark, 03-10-2007 13:20:45
Thanks,guys.
