john deere d brakes
bigmur
03-10-2007 07:07:22
I am currenty restoring my grandfathers D model john deere tractor. I am not for sure on the year model of it but it is a styled D. I purchased another D that is really similar to my grandfathers except fot the fact that it has rear turning brakes where as my grandfathers tractor does not. i plan on doing some pulling with it and i would like to change them over, but i dont know if they interchange does anyone know know the brake system on these tractors
Glen in TX
03-10-2007 07:43:31
 Re: john deere d brakes in reply to bigmur, 03-10-2007 07:07:22
Bigmur, The individual wheel brakes or turning brakes are mounted a different axle quill. You could change them over but would have to pull the large bull gears off inside that run on chain and switch the axle quills that brakes mounting plate presses onto. The cast centers for drums are a lot heavier to handle also. The styled D parts catalog PC659 shows the brake setup. Axles, bearings, and seals are the same only the axle quill casting if different for brake parts to mount on. If something is missing from the brake set up I have a few of those parts yet but those with turning brakes and parts are hard to find now it seems. Go over to johnnypopper.com and talk to Brandon about the unstyled DI he is working on with turning brakes. Later unstyled Ds used the same turning brake setup also. Keep the D with those brakes if you decide not to switch it over as there weren't many made with those type brakes and don't see them often. Myself I would keep the family tractor original and pull the other one with the brakes. It is going to weigh a lot more too with those type brakes and heavier cast centers that act as drums also.
WeirdDeere
03-10-2007 15:26:16
 Re: john deere d brakes in reply to Glen in TX, 03-10-2007 07:43:31
Ditto on Glen's comments. I'm the Brandon he mentioned by the way. I wouldn't do the switch unless it is something you REALLY want to do. Just pulled an axle housing out this afternoon off of the DI (need to fix seals). It is a pain, and heavy. And I had HELP!
Besides, I don't know if the wheel brakes are enough of an advantage in a pull to do the swap?
Brandon
