Hercules or JD (L)
ccrock
03-10-2007 04:14:40
What is the easiest and best way to visually tell if an L has a Hercules or JD motor?
GWG
03-10-2007 04:45:01
 Re: Hercules or JD (L) in reply to ccrock, 03-10-2007 04:14:40
On the Hercules engine the oil filler pipe on the left side of the engine is vertical or straight up the flywheel housing is bolted to the engine block the spark plugs are closer together two fingers wide
n29we
03-10-2007 14:30:27
 Re: Hercules or JD (L) in reply to GWG, 03-10-2007 04:45:01
I'll just eloborate a litte on GWG comments. The oil filler pipe is vertical on the Herc and angled on the JD engine. The flywheel/clutch housing on the Herc. is bolted to the engine block. The JD engine, flywheel, and clutch housing are all one cast piece. The JD engine has the ability to have electric start. It is mounted on the topv rear of the engine where the aircleaner assembly is on the Herc. The JD has the external vertical air cleaner. JimO
