4020 loader joystick hookup
chucky
03-09-2007 18:55:27
I dont know if it is just my 4020 but the line that everybody talks about in the archives is not on my 4020.
I have one line that has a 7/8 tappered fit that goes in to a adappter to a 7/8 o-ring end that goes into the rockshaft housing. The line come straight back from the dask cowl area.
My uncle who worked for a JD dealership for 18 years never remember seeing one like this before.
I all ready have the 2640 oil filter cap but am having a hard time tapping into the pressure side.
I was able to find a T that has one 7/8 o-ring side and two 7/8 tappered side but the mounting location is to close to allow the T to thread in.
If it madders it is a 1970 LP tractor with out differantal lock. Any help would be apprecated.
My Deere dealer, uncle,and myself have not got this one figured out yet.
Thanks Chuck
chucky
03-10-2007 16:55:41
 Re: 4020 loader joystick hookup in reply to chucky, 03-09-2007 18:55:27
Thanks for the help guys!!!
Chucky
Mike W J
03-10-2007 10:59:30
your tractor is a 1970 so John deere makes a auxiliary outlet manifold just for loaders and such that have there own control .It goes ahead of your SCV valve so you get full pump flow without Scv restrictions I bought one on EBAY for $41 You might be able to see it yet it was item number 220074813886 Or got to JD parts and look up part number RE54312 It is $185 at John deere.
Gerald J.
03-09-2007 21:06:46
third party image
Its more work, but you can tap into the pressure feed for the SCV. For that late 4020, Deere makes a plate that fits behind the SCV mounting and brings out both pressure and a return. Don't need the tapped oil filter cover with that.
This picture is what I did to my 1968 4020 to make two taps. My return is to the oil filter cover.
Gerald J.
TimS in Mo
03-09-2007 19:59:45
Where does the line come from that goes to your rockshaft housing? It should come from a 90 degree elbow down near the brake pedal...that is the one that you take out and replace with a T.
