I have fixed a few, and my advice would be to give up on the old hole if at all possible. TiG it shut if it bothers you, but move over to the left or to the right 120* and have a look. There should be two other bosses in that pulley where a new pin hole can be drilled, then end milled or reamed to a TIGHT press fit to the dowel pin. You really want to be using the hardened dowel pin that is called out as even a grade 8 bolt will chafe and fret over time. After welding up the sleeve boss, and grinding the surface to properly center punch for the hole location, drill a hole EXACTLY the same distance from the center of rotation as you located the pin. If you use a mill or a jog bore it makes this job a piece of cake. Find a reemer that will open the hole just a few thousandths and try that. I have some specific information at home, but I am on the road right now, so my memory is the best I can offer. You'll want the pin to slide on the sleeve without binding or dragging, but the tighter you can keep the pin to the bore clearance the better. After you do this, slide it on to the crank and check that it slides in and out without dragging or chattering. If the pin is not parallel with the centerline of the bore of the hole, and not coaxially located, you will have problems. Some folks have over bored the sleeve boss and then sweated in a harder bushing, then mill that to size to minimize the wear between the soft sleeve boss and the hard pin, but that makes for tougher maching, and besides, it took 50+ years to get worn that much, so this fix ought to last at least that long as well. It's not a tough job, but it takes some set up time and a lot of checking before you make the first plunge. Frank
