Carburetor blues
Bullfiddler
03-09-2007 15:26:55
Working on a JD model 301a with a carb problem. While running, it will all of the sudden start running rich and leak fuel out of the bottom. It almost always runs rich after having it running wide open than shutting the throttle closed. We have had the dang thing apart 4 times and checked the needle valve and checked the float, everything appears to be working as designed. I should note that this a Zenith replacement not a factory Marvel-Schebler. Any ideas??
Marvscheb
03-10-2007 16:42:10
 Re: Carburetor blues in reply to Bullfiddler, 03-09-2007 15:26:55
Hi Bullfiddler, You might check and see if there is too much bull and way to much fiddlin ---- Just kiddin Hey about your carb. Running rich under any conditions can almost always be attributed to either float or float valve needle and seat trouble along with bad adjustments Your adjustments may be out of wack. If the engine dont run good enough to accomplish accurate adjustments then you must first discover why that there is too much gas in the mixture. Since your carb is flooding over at various times we know the float float valve needle and seat are all suspect and will most likely be the problem.the best way to discover what is happening is to first remove the float and dry it real good with paper towel then place over a real clean brown paper bag gently bump the float up and down on the bag looking for wet spots on float or dripping gas leaking out. Next warm float with momma's hair dryer gasoline expands fast and will leak out wetting the float when heat and rotate in all directions. Next the hot water test mentioned above is done by heating water to 140 to 150 deg F. Then immerse float breifly observing any bubbles (steady flow) from leak. Once the float warms up to water temp flow of bubbles will slow but to repeat the test cool float under cold water tap then reimmerse. The other quandry is the needle and seat. Are you using a Viton tip needle. Even on brand new needle seat sets I have many times found leak failure on my test stand. Some times looking with a magnifying glass you can see tooling chatter marks left on the contact zone in the seat. I have also many times polished the seat to a very fine finish, solves the problem. I also have come to depise that Zenith "One size fits all" carburetor. You might also check to see that your choke butterfy is all in order If it is loose or the choke shaft is not held open when running the engine it will cause rich engine operation or even flooding over. I have found loose choke cables or loose choke shaft levers can cause major trouble. I believe this tractor has a fuel pump and you need to make sure that it is not producing excessive pressure. Your float in the carb is designed to only hold back bout 4lbs pressure. send me an e-mail Ray
Bullfiddler
03-11-2007 14:11:23
 Re: Carburetor blues in reply to Marvscheb, 03-10-2007 16:42:10
As we speak right now, I was running it yesterday and it shut off. Thought I was low on gas so put some more in and still wouldn't start. Come to find out wasn't getting any out of the output of the fuel pump... beginning to wonder if the pump was going bad or acting goofy since day one when it started to flood like your idea about having too much fuel pressure.
Mike M
03-10-2007 06:07:31
Make sure the bowl vent is open too.
Glen in TX
03-09-2007 18:19:57
Something like a universal Zenith 14996 aluminum body, older cast iron or one with the electric solenoid control valve on it? A model should be stamped on top carb housing on a flat area on top. Make sure the float isn't leaking and fuel heavy laden by shaking it listening for fuel in it. Can also check float for leaks by holding it with pliers in hot water, not boiling, and you will see air bubbles spewing where there is a leak. If float is crushed or colapsed some replace it. Make sure the gasket seals and is there under the seat for needle. Has the carb always been on there or did you purchase it new or used rebuilt? Reason I ask that is check with a parts sheet included with most kits and make sure one of internal jets isn't missing. If it has a solenoid type idle needle it may be faulty or just full of crud needing cleaning. Run wires or small drill bits thru passages making sure they are clean and spraying clean with carb cleaner. Make sure the float isn't dragging against housing inside noting if bent or scratches on it.
