'38 governor problems
BobinKs
03-09-2007 13:43:20
I was running my A today and it decided I needed something to do. It was idling along just fine. Then it stopped firing and began to wind down. As it got slower I could hear a sort of grinding that I later determined to be comming from the governor. I pulled looked in the crank case and everthing looked good. The valves looked fine. I then took the flywheel side of the goveror off and I the bearings were not all there. Is it possible that the bearings are the only problem and if I change them clean out the crankcase for missing bearings do you think it will be okay or should I just go ahead and remove the governor and check it all out. I know I should do that but I want to work on my B that I just got. Also is it possible to remove the governor without taking the radiator off. I know I will need to remove the hood and gas tank, but I was thinking I might be able to unbolt the fan and slide the governor out without removing all the other stuff?
Larry Baker
03-11-2007 05:56:03
 Re: '38 governor problems in reply to BobinKs, 03-09-2007 13:43:20
if you are going to leave the rad in got a helpful idea that wasnt mind but i use now
i was told to put a piece of cardboard between the rad and fan and save a lot of damage
well we have done it several times and it works
just cut you a piece big enough to protect the rad and pull it out when you are done
i use it now when we put new rad. in so not to damage the fins and just pull it out when you get it in place
Deere Heaven
03-10-2007 06:22:18
Yes you can remove the govenor with out taking the radiator off. just make sure you take the oil line off that feeds the govenor. You will need to slide the fan as close to the radiator as you can.
