DRV2B Mag. Impulse Coupler
ET
03-09-2007 08:45:29
Some time a short while ago there was a post about using a newer impulse coupler on the old fairbanks morse magnetos. What is the correct lag angle of the newer impulse. I have a mag I got a while ago with a newer coupling on it, marked 35 degree's and it does not snap at the correct time. I have the gears timed with the red line on the big one aligned with the slant tooth on the rotor gear.
ET
03-09-2007 10:33:01
 Re: DRV2B Mag. Impulse Coupler in reply to ET, 03-09-2007 08:45:29
Glen thanks for the reply. My hub is maked UBL with rounded shoulders. It says 35 degree on the back and when the trip pins are horizontal like you said the key is headed foe 11:00 or 5:00 so it is the wrong on like I kind of suspected. I have a few fairbanks FM mags around for wisconson engines and allis-chalmers. What are chances of any of them having the right coupler?
Glen in TX
03-09-2007 14:15:15
 Re: DRV2B Mag. Impulse Coupler in reply to ET, 03-09-2007 10:33:01
third party image
ET, Sorry I didn't explain that very well and you do have the correct drive cup and it should be marked UBL. U = series U impulse, B = 5/16" lug, L = LH or CCW drive rotation. All flange mount mags would use the 5/16" lug. A cup being marked only UB would be for CW drive. The UAL drive cup would only have 1/4" lugs which is what the A stands for. So UAL is not correct for the flange mount mag with 1/4" lugs being used mainly on base mount mags. You might get lucky finding one of the universal hubs with 3 keyways cut into it with the one marked JD 35� but most only had one keyway cut in them and those other FM mags that are CW drive facing the drive end are going to have the wrong 35� hub. Email is open if you want to discuss getting the correct hub. [email protected] AC used CW 35� mag so wrong rotation and most Wisconsin mags are going to have CW 15 or 20� impulses. There were lots of applications and impulses back then being explained in just a 45 page bulletin in the FM mag book in 1959 and a few more years after that. That's why the Wico XH became a more common replacement later on because of the variable impulse to fit more applications easier.
Glen in TX
03-09-2007 09:31:29
Fairbanks Morse mags didn't have adjustable impulse so you have to have the correct impulse hub with keyway cut in the correct place to change it. Someone in the past probably has put the wrong 35� impulse put on it sounds like to me. The keyway is cut in a different place in impulse hub for the JD application yet the hub may be stamped 35�. Earlier FM RV mags used a W or X impulse and on those the drive shell is more squared off. The later U series impulse drive shell is more rounded off on edges and your drive shell should be stamped UAL and hub may or may not be stamped UB 3 35�. There was also a 25� one could be put on but those are hard to find now. FM also made a impulse hub that had 3 keyways cut in the hub for 20, 35,& 35 UB 3 JD degrees. Many of those have one key way that is stamped JD 35�. One way to tell if have the correct impulse hub is look at it with trip dog pins in a horizontal position and keyway should be in a 2:30 or 8:30 o'clock position for CCW drive JD application. If keyway is in 5 or 11 o'clock position with pins horizontal you have the wrong impulse hub and one for CW drive. Drive cup should be stamped UA or UAL not UB. UA & UAL are for CCW drive like on JD. UB is CW drive cup. If you have the wrong impulse email me as I still have a few of the correct ones yet.
