4020 rockshaft update
Jason Z in MO
03-09-2007 08:08:34
Thought I would provide an update on the rockshaft cylinder scoring problem.
I checked with ValTec who is a big hydaulic builder and repair shop. They don't recommend honing the cylinder because the seal would fail at much lighter loads so and oversized piston would be needed. Not built by Deere. It could be bored and sleeved but there would have to be a way to stake the sleave to prevent slipping. Not a good option.
The part AR32904 (casting R33880R) is not available from Deere and not in any dealer inventory.
So, I've been searching salvage yards with no luck so far. If anyone has any leads let me know.
Thanks,
Jason
[email protected]
G/MAN
03-10-2007 11:27:10
 Re: 4020 rockshaft update in reply to Jason Z in MO, 03-09-2007 08:08:34
I don't know how the sleeve would "slip". All that would be required is to leave a step at the front of the bored area for the sleeve to seat against in order to prevent it from "slipping" forward, and the end cover is going to prevent it from "slipping" backward. Also, lightly honing the cylinder to remove as much scoring as possible isn't going to affect piston seals. Those rockshaft pistons fit much more tightely in their bores than do the average hydraulic cylinder pistons, because the piston "floats" in the bore and has no rigidly connected rod to help locate it in the bore. Just from my fair amount of experience with rockshaft housings from various models of Deere tractors, I think that the housing could be sleeved effectively and relatively easily, but maybe not "cheaply". If you plan to replace the housing, you're going to have to remove the old one regardless, so I sure wouldn't hesitate to toss the old one in the back of the truck and visit a couple of machine shops and get their opinion of the situation, particularly if you want an "ideal" bore. You're simply not going to find a "perfect" rockshaft housing with an absolutely smooth and scratch-free bore, particuarly as you're having trouble finding any used one at all.
JDBert
03-09-2007 12:21:19
Jason-
I'd try the classifieds at www.pulloff.com heck maybe even put a wanted add on there. Like Frank listed you can try those guys usually over priced I think or ASAP ag parts, theres also a guy that advertises in Green Mag that has nothing but 10-55 series parts, dont have a mag handy otherwise I'd drop the phone # for ya. If you bore it bigger and have a custom piston made- would that affect the system at all by throwing pressures outa whack maybe?? Just a thought BUT did you try a 3020 houseing??
Mike M
03-09-2007 08:18:42
I have had 2cyl. engine blocks sleeved and they didn't slip. Some times they even put some brass pins in to help hold them. A good press fit should hold them. On that rockshaft you may be able to counterbore the end the cover bolts on and use a flanged sleeve ?
There's a bunch of 4020's for salvage around here in Ohio but I wouldn't have a clue how much a rockshaft would cost ? Will one from a 4010 work ? alot of guys are tractor pulling them and they have no need for a rockshaft it might be another source ?
Jason Z in MO
03-09-2007 09:10:42
 Re: 4020 rockshaft update in reply to Mike M, 03-09-2007 08:18:42
Mike, I'm sure your right but I was told by a few people it would be pretty costly. However I didn't show up in there shop so they could actually give me a quote. The option isn't completely ruled out.
Checked on the 4010 idea and the part number is close AR32906 but I need AR32904 (casting numbers are not so close...) Good idea though!
I'll do some checking with the pulling groups too!
