Deere M oil filter cover
mdmccool
03-08-2007 10:19:15
Hello-
I have a '49 Deere M and the oil filter bell cover is leaking on the outside, between the bolt head and the copper washer. How do I remove the bolt from the spring housing on the inside of the filter bell so I can replace the washer? What am I missing???? I tried but have had no luck.
Thanks,
Matt
NJ
jd51mt
03-08-2007 12:52:50
 Re: Deere M oil filter cover in reply to mdmccool, 03-08-2007 10:19:15
Matt,
It will have to be pressed out using an arbor press. Before you do that, do you have a plate (looks like a big washer) under the filter element? If not you may want to get one and try that first.
MIke
mdmccool
03-08-2007 13:46:40
 Re: Deere M oil filter cover in reply to jd51mt, 03-08-2007 12:52:50
Hi Mike-
I do have the plate - it looks like a big washer and it has a spring behind it. That spring keeps tention forced toward the open end of the filter "bell" and all seems to be held in place by a brass bushing.
Thanks for your reply,
Matt
bill mar
03-08-2007 15:36:20
 Re: Deere M oil filter cover in reply to mdmccool, 03-08-2007 13:46:40
look in a parts manual,jd51mt is talking about a plate that looks like a large flat washer that goes "under" the filter(not the end that goes up in the bell shaped canister.
