Hyd. GPM flow on a 1020
J T O
01-03-2000 18:05:48
Does anyone know what the GPM flow rate is for the hyd. pump on a JD 1020 ..... thanks JTO
david val
01-04-2000 08:49:39
 Re: Hyd. GPM flow on a 1020 in reply to J T O, 01-03-2000 18:05:48
1020 with power steering and closed center hydraulics has about 13 gpm at 2000 rpm. thats max pump output, good for a short period only.
contineus flow should not be more then 4gpm. if you need more you have to put on a special hyd filter housing with porting and return the oil through it.
david
J T O ......thanks David ......
01-05-2000 20:39:51
 Re: Re: Hyd. GPM flow on a 1020 in reply to david val, 01-04-2000 08:49:39
