Converting a 4230 to 4WD
C Clark
03-07-2007 02:30:48
I have a 4230 with power assisted front wheels. Could I convert this into a proper 4WD using the axle out of another tractor? Are the transmissions the same (it has a shift on the move trans)?
C Clark
buickanddeere
03-07-2007 13:00:05
 Re: Converting a 4230 to 4WD in reply to C Clark, 03-07-2007 02:30:48
I don't know what you paid for the 4230 but it likley would have made a decent down payment on a 5603 or a 6603 m4wd. A M4wd conversion on a 4230 would be an expensive and time consuming hobby. The 30 sereis cabs are comfy & quiet. The engines however needed higher comp pistons, higher valve seat heights and a larger starter motor.
flying belgian
03-07-2007 06:34:01
I bought a 4230 last fall and am real dissapointed with it. Mine starts hard and I don't think it pulls anymore then my old 706 Farmall gas. It sure is a nice quiet and comfortable tractor to operate though. Just wondering what you thought of yours?
C Clark
03-07-2007 11:18:40
 Re: Converting a 4230 to 4WD in reply to flying belgian, 03-07-2007 06:34:01
Mine is also hard to start, sometimes requiring either on cold mornings. I agree, they are a comfortable tractor to operate; all the controls are placed close to the operator, and being able to change on the move. Don't do much pulling with it put for a tractor its size it doesn't do to bad.
buickanddeere
03-10-2007 07:20:30
 Re: Converting a 4230 to 4WD in reply to C Clark, 03-07-2007 11:18:40
Do you mean you haven't been using the block heater at temps below 40F ?
C Clark
03-07-2007 11:18:39
buickanddeere
03-07-2007 13:02:05
 Re: Converting a 4230 to 4WD in reply to C Clark, 03-07-2007 11:18:39
Come to think of it. Dad's old 4230 was loosing almost 2V on the starter cables. The connections all needed cleaned incluiding the return on the engine block.It was an altogether different tractor after that.
MSM
03-07-2007 05:53:18
No it will not convert to MFWD. There is no place on the transmission,nor the internal gearing to attach a driveshaft to run the front axle. If you want MFWD you need to look for a 4250.
C Clark
03-07-2007 11:12:02
 Re: Converting a 4230 to 4WD in reply to MSM, 03-07-2007 05:53:18
Thanks
