6.50-10 Tire -- What does it Fit?
P Browning
03-06-2007 14:55:46
I am getting ready to market a tire of 1936 BN (Its the wrong size for the BN).
It is a 3-rib 6.50-10 4-ply rated nylon tire by Firestone. Does anyone on this board know what brand tractors would have called for this size in front?
Once I have a clue, then I will know where to place my classified ad. This post IS NOT A FOR SALE item! Thanks - PatB
Gerald J.
03-08-2007 08:29:17
 Re: 6.50-10 Tire -- What does it Fit? in reply to P Browning, 03-06-2007 14:55:46
According to an article in 1999 in 2 cylinder magazine the JD 430 -3T forklift used two 650-10 on the steering wheels. The single wheel 420T/430T used 7.50-10.
Looks like an MT or 40T single wheel has a chance of using that size but I don't have information on those.
Gerald J.
dds-inc
03-07-2007 16:25:15
how about a john deere MT with a single front!!!!! !! did i get it right?
BRUSTER
03-07-2007 08:08:19
Ya know, 10" seems darn small for a steer tire, since a wheelbarrow tire is 8". Could be an implement tire!
Ron in NE Colo
03-07-2007 06:58:32
How about a JD HN?
P Browning
03-07-2007 11:56:44
 Re: 6.50-10 Tire -- What does it Fit? in reply to Ron in NE Colo, 03-07-2007 06:58:32
Would you believe a JD-HN takes a 6.00-12 tire? A 10-inch front was standard for the JD-B tractors and also (I believe) on into the model 50, but the tire size alternatives were 7.50 or 9.00 by 10-inch. Some dorky-bird installed a 6.50-10 on this BN for what reason I do not know. It is a new tire -- still have the mold teats on all three ribs and the painted-on arrow of rotation direction -- on the center rib. So, if this tire ever carried weight, it couldn't have been very far! I am just trying to find a home for it. But before I try to market the tire, I would like to learn if there is any tractor out there that it will fit onto. Perhaps I should give Miller Tire a call!! I will probably install a 9.00-10 tire in its place. (PatB)
F-I-T
03-06-2007 16:47:27
third party image
I thought I was on to something, but no go. I thought the single front tire used on a VAC Case was about that size, but it turns out it was 6.00x12.
The only place I can remember a 6.50x10 is on some medium-sized twin engined aircraft such as the Cessna 310's, but they used 6 ply 6.50x10's, and not tri-ribbed.
Loren in Florida
03-06-2007 18:36:25
 Re: 6.50-10 Tire -- What does it Fit? in reply to F-I-T, 03-06-2007 16:47:27
Just a stab in the dark, but what size did the JD 50 Barber-Greene use. Pictures look like it could be close.
Ten-Twenty
03-07-2007 04:52:53
 Re: 6.50-10 Tire -- What does it Fit? in reply to Loren in Florida, 03-06-2007 18:36:25
The Barber -Greene Model 50 used a 9.00x10 single front.
F-I-T
03-06-2007 19:24:08
I've only seen one of those up close, but it seems to me it was taller than a 10". Just don't know.
